Throttle body injectors are giving too much gas?
230,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
5150JNB
Truck starts and runs fine for the first 15 to 20 minutes and then floods out if I disconnect one injector it will crank back up and run.
Jan 5, 2023 at 1:11 PM
  • 55,464 POSTS
So, what happens is the fuel injector can short out causing the PCM to turn the injector on full blast, I would disconnect the injector and use an OHM's meter to check the windings, this guide can help:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
The other options are the PCM injector driver is shorting out or you have a bad ground for the computer. Let us know what happens and please upload pictures or videos of the problem.
Jan 6, 2023 at 4:23 AM
