Codes P1440 and P1443
165,000 MILES • 1.6L • 2WD • MANUAL
KNOWSALITTLE
Hiya. I'm a woman and most think we have no clue but I hope someone can help me.
Car started rough idling and bouncing mad so cleaned throttle body and changed EGR valve as the old mount holding it snapped when being removed. Anyway, got a new one and put it all back together but now the car has another problem...
It idles at 1,100-1,200 RPMs, bearing in mind my normal idle was about 400-600 RPMs. I plugged a vag in and came back with codes P1440 + P1443 for a peridiometer fault.
How can i fix this? Someone? Anyone. Need car for school run..
Tia guys.
PS. EGR valve, mount and gaskets all new.
Mar 22, 2021 at 8:17 PM
BORIS K
  • 836 POSTS
It sounds like you either have a wiring issue at the EGR valve potentiometer or further down the line towards the ECU.
Did you carry out an adaptation process after you installed the new EGR valve?
If your scan tool is bi-directional then you could perform an Output Test to check if the EGR valve is responding
If possible also perform a throttle body adaptation with your scan tool, this could sort your high idle:
P1443
Possible Causes
Wiring and/or Connector(s) from/to Potentiometer for Exhaust Gas Recirculation (G212) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/faulty
Possible Solutions
Check Wiring and/or Connector(s) from/to Potentiometer for Exhaust Gas Recirculation (G212)
Check/Replace Exhaust Gas Recirculation (EGR) Valve (N18)
Perform Output Test
Check Exhaust Gas Recirculation (EGR) System
Let us know what you find.
Boris
Mar 24, 2021 at 2:31 AM
