After replacing the throttle body nothing happens when pressing the accelerator pedal?
69,085 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
MONCHO6685
  • 118 POSTS
I have change the for the car listed above but i need to know if i need to make a relearn to it?. The problem is that now it doesn't work. I press the gas pedal and doesn't do anything.
Can you help me?
Thanks,
Juan Marín
Jul 2, 2021 at 11:31 PM
Good morning,
I attached the location of the throttle body. It is on the end of the upper intake manifold. It is held by 3 bolts, an electrical connector, and a hose.
There is no relearn for this. It is a plug-and-play replacement. I attached the part as well for you.
Jul 3, 2021 at 12:23 AM
MONCHO6685
  • 118 POSTS
Thanks Asemaster6371. I'm going to change it and let you know what happened. If the PCM is bad, it can cause that the accelerator actuator at the throttle body do not respond?? I have the signal from the pedal, but something it's wrong.
The code that i pull out from the scanner is p2101.
Thanks,
Juan Marin
Jul 3, 2021 at 1:04 AM
MONCHO6685
  • 118 POSTS
Hi. I change the throttle body but it didn't work. Does not accelerate. I have a signal from the acceleration pedal. I looked for the connection for any damage, but everything looks fine. Is there any relay that controls the throttle body? Can you send me how to test the ECM to see if it's working correctly?
Thank you,
Juan Marin
Jul 4, 2021 at 12:44 AM
Okay, do you have an advanced scan tool that can read the commands to the throttle body?
I attached the wiring diagram of the system for you. I highlighted the wires for you of the throttle body and the pedal sensor.
I also attached the flow chart for the throttle body operation.
Jul 4, 2021 at 1:46 AM
MONCHO6685
  • 118 POSTS
Hi. Yes i have an advance.
Bi-directional scan tool i can see live data and commands.thank you so much Roy. I let you know the results.
Att. Juan Marin
Jul 4, 2021 at 2:11 AM
You are welcome.
Always glad to help.
Jul 4, 2021 at 2:12 AM
