Throttle body swap?
156,100 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
RDEVO
Will any throttle body work for my van or does it have to be an original part like Mopar?
Nov 1, 2024 at 1:29 AM
STEVE W.
  • 15,410 POSTS
It doesn't have to be a Mopar part, but it does have to be the correct part for the engine and control system. So, you can't take the throttle body off a hemi and put it on your engine. However, some vehicle control systems are very fussy about the parts connected to them and it's possible for a low-quality part to cause error codes or even running problems because of the way they are made. That is one reason why I try to always use OE parts for things like that. So, for your vehicle the OE part is #4593858AB but there are a few aftermarket parts as well as remanufactured OE units. If your testing shows the TB is bad, then I would suggest a rebuilt unit or see if you can get a used OE part.
Nov 1, 2024 at 4:25 AM
