With vehicle turn off the electric power remains feeding the Throttle body?
120,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
ABAYA
  • 77 POSTS
When i cut off the engine the electric power remains feeding the throttle body and i hear low whistling coming from the throttle body.
Please excuse my bad English.
May 14, 2025 at 2:25 AM
ABAYA
  • 77 POSTS
I want to add that the engine starts and accelerates without any difficulty. But every morning I find the battery drained.
Thank you, sir.
May 14, 2025 at 5:17 PM
  • 55,732 POSTS
Can you upload a short video of the noise so I can hear it? You can upload it here with your response.
May 16, 2025 at 3:01 AM
ABAYA
  • 77 POSTS
Sorry, the sound coming out from the throttle body is very low.it seems that the electric motor is unable to close the throttle body gate. But when I take off the battery negative wire, the gate gets closed.
Excuse my bad English Mr. Ken
Thank you very much.
May 16, 2025 at 5:18 PM
  • 55,732 POSTS
No problem, I would unplug the throttle body to see if the noise goes away and if so, replace the throttle body. Thanks for the video, it helps.
May 18, 2025 at 10:43 AM
ABAYA
  • 77 POSTS
Thank you Mr. Ken.
It's exactly like what you said.
It's helpful.
May 18, 2025 at 3:07 PM
  • 55,732 POSTS
Together we can fix it! :)
May 19, 2025 at 2:36 AM
ABAYA
  • 77 POSTS
Hi.
Today i'll replace a new throttle body.
I'll let you know the result.
May 20, 2025 at 1:13 PM
  • 55,732 POSTS
Sounds good, thanks for letting me know.
May 22, 2025 at 2:56 AM
ABAYA
  • 77 POSTS
Hi. Mr .Ken
Is a bad reprogrammation of the ecu can lead to this problem?
I must say that the engine run normally .
May 22, 2025 at 7:28 AM
  • 55,732 POSTS
Yep, I can't count how many times reprogramming fixed strange issues. Can I ask what problems remain?
May 23, 2025 at 4:05 AM
ABAYA
  • 77 POSTS
Hi, mr. Ken
Is a bad reprogrammation can led to the problem I encounter in the throttle body ? My throttle body remain open after turning off the engine.
May 23, 2025 at 4:14 AM
  • 55,732 POSTS
That can be normal as long as it closes on start up.
May 23, 2025 at 4:41 AM
ABAYA
  • 77 POSTS
Thank mr. Ken
But it remains open after I cut off the engine.
May 23, 2025 at 5:11 AM
  • 55,732 POSTS
Yes, this is to allows gas fumes to dissipate, I think it is normal but you can try a new part and see if it does the same thing.
May 23, 2025 at 6:03 AM
ABAYA
  • 77 POSTS
Thank you
May 23, 2025 at 6:57 AM
  • 55,732 POSTS
You are welcome, have a great weekend!
May 23, 2025 at 9:09 AM
ABAYA
  • 77 POSTS
May 25, 2025 at 1:11 AM
