Throttle body
170,000 MILES • 2.4L • 4 CYL • RWD • AUTOMATIC
JOE CAMACHO
The vehicle sounds like it is going to stall when idle. It also will not stay idle when starting. I need to give it gas and then drive with both the brake and gas pedal just for thirty seconds then it will stay idle, but feels like it will stall. I have cleaned the throttle body and the IAC. A lot of gunk came out but it did not cure it. Can you suggest something. Thank you.
Dec 17, 2016 at 7:50 AM
HMAC300
  • 48,601 POSTS
hopefully you cleaned both sides of throttle plate. check fuel pressure with a guage auto parts rent it, see link.
Dec 18, 2016 at 12:31 AM
