Lost power and check engine light turned on
138,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
BELARUS89
  • 5 POSTS
My car suddenly slowed from 65 mph to 40 mph check engine light came on. Went to auto parts after the scan he said throttle body actuator was malfunctioning. Question is, how difficult to replace? I went to dealer the part is over $400.00. I do not want to mess up the part. And does the scan answer sound correct?
Nov 2, 2018 at 12:02 PM
  • 110,248 POSTS
It is possible that is the problem. However, I would rather see the code they found to make a better determination.
As far as replacing the part, it is not hard. Here are the directions. All attached pictures correlate with these directions.
___________________________
Throttle Body Assembly Replacement
Removal Procedure
1. Remove the air cleaner outlet duct.
2. Remove the secondary air injection (AIR) feed tube, if equipped.
3. Disconnect the engine harness electrical connector (1) from the throttle actuator.
4. Loosen the throttle body bolts.
5. Remove the throttle body nuts.
6. Remove the throttle body and seal.
Installation Procedure
1. Install the throttle body and seal.
2. Apply threadlock GM P/N 12345382 (Canadian P/N 10953489) or equivalent to the nuts.
3. Install the throttle body nuts.
Notice: Refer to Fastener Notice.
4. Tighten the throttle body bolts/nuts.
Tighten the bolts/nuts to 10 N.m (89 lb in).
5. Connect the engine harness electrical connector (1) to the throttle actuator.
6. Install the AIR feed tube, if equipped.
7. Install the air cleaner outlet duct.
____________________________________
Nov 2, 2018 at 12:32 PM
BELARUS89
  • 5 POSTS
Thanks for the quick response. I was in a rush at the time and had a senior moment or would have gotten the code, will go back today and retrieve it. Thanks again, Jim.
Nov 2, 2018 at 9:17 PM
  • 110,248 POSTS
Hi, Jim, and welcome back. I am starting to have those moments all the time. LOL I would hate to tell you just to replace the part without knowing for sure there is not other possible issue causing the problem.
Regardless, let me know what you find.
Take care.
Nov 3, 2018 at 9:07 AM
BELARUS89
  • 5 POSTS
I totally understand your reasoning. Went to the auto parts he said that it was dealer part only. So my daughter (since it is her auto) decided to have the dealer do the repair. However you have a great channel have learned a lot reading the other posts. Thanks again, Jim.
Nov 3, 2018 at 9:52 AM
  • 110,248 POSTS
Glad to help.
Take care and let us know if you have questions in the future.
Nov 3, 2018 at 10:24 AM
