Throttle body reprogramming
137,544 MILES • 3.3L • V6 • 2WD • AUTOMATIC
LANDSCAPE SANCHEZ
If i put a new throttle body do i need to reprogramming?
Dec 25, 2018 at 8:11 AM
Good evening,
Once you replace the throttle body the ETC electronic throttle control needs to be relearned.
it needs to be done with scan tool. I looked for a procedure without the scan tool but there is no procedure other than using a scan tool.
after installing, you should take it to a shop and have them do the procedure for you.
6. Tighten the bolts in a mandatory torque criss - cross pattern sequence to 7.5 Nm (65 in. lbs.).
7. Install clean air hose and tighten clamps to 4 Nm (35 in. lbs.).
8. Connect negative battery cable, tighten nut to 5 Nm (45 in. lbs.).
9. Use a scan tool and perform the ETC RELEARN function.
Dec 25, 2018 at 9:19 AM
