Throttle body replacement and do I need to do relearn procedure?
2,007 MILES • 1.8L • 4 CYL • 2WD
RAYMOND FILIPO
  • 7 POSTS
Hi, there if your going to replace the throttle body which is run by cable do you still need to do the relearn procedure?
Nov 15, 2020 at 11:36 AM
We don't offer the Tino here in the USA so I don't have the manual on that vehicle but it is basically the same as a Sentra with the 1.8L. I attached the relearn process for the air volume which is all that you need to do after replacing the throttle body.
You can do this with a scan tool but I assume you don't have one so I attached the process to do this without the tool. Let me know what questions you have and we can go from there. Thanks
Nov 16, 2020 at 6:30 AM
