Throttle body actuator relearn
2013 FORD TAURUS
200,000 MILES • 2.0L • 4 CYL • TURBO
DARYLLE JEFFERSON
How to relearn throttle body actuator?
May 6, 2020 at 12:05 PM
  • 110,241 POSTS
Are you referring to the throttle position sensor? If so, there isn't a relearn for it. If you installed one and are having issues, make sure the sensor is properly installed. Take a look through this and let me know if it helps.
______________________
Installation
1. NOTE: When installing the new TP (Throttle Position) sensor, make sure that the radial locator tab on the TP (Throttle Position) sensor is aligned with the radial locator hole on the ETB (Electronic Throttle Body).
NOTE: Do not use power tools.
Install the new TP (Throttle Position) sensor.
- Using hand tools, install the 2 new bolts.
- Tighten to 3 Nm (27 lb-in).
pic 1
2. Connect the TP (Throttle Position) sensor electrical connector.
_______________________________
Let me know. Also, if this isn't what you are referring to, let me know what is happening.
May 6, 2020 at 2:04 PM
