throttle
48,000 MILES • 3.6L • V6 • AUTOMATIC
WALTBK
Something seems horribly "off" with the pedal position vs. the throttle opening. From stop, extremely light touch to the pedal makes the van "jump" ahead, usually with tire chirping. Pedal down halfway produces dramatic tire spin (including downshifting if already moving), yet "pedal to the metal" makes no noticeable difference. Is the throttle electronically controlled? Can the position/response be adjusted?
Aug 2, 2025 at 11:34 PM
STEVE W.
  • 15,387 POSTS
Your description sounds like it has something like a throttle commander installed, that is exactly how those work. They basically trick the ECU into thinking you are pushing the pedal farther and faster than you really are. So you step down slightly and it doubles that. Most of them are plug in devices that go between the throttle pedal connections and have a control box. The throttle is fully electronic on that van and isn't adjustable that way unless you go into the coding and rewrite it. The pedal is basically two potentiometers that operate independently and in reverse of each other. They have two 5 volt sources and two grounds and one raise the voltage while the other lowers it, the PCM uses both to determine throttle input. It will also trigger a light if there is a problem. Probably the first thing would be to use a scan tool and see if the pedal inputs are correct. It would read a percentage and the voltages the pedal has to it, you would be looking to see if the pedal showed say 7 volts instead of 5 or that pressing half way reads over 50 percent throttle.
Did this just start happening or is this a recent purchase that is acting strange?
Aug 3, 2025 at 3:29 AM
WALTBK
Hi Steve. Thanks for the response. I bought the van in 2020 w/36,000 miles on it, and it was like this when I bought it. Your suggestions seem like procedures that I'm not qualified to handle. Dou you think I can trust a Chrysler dealer with it?
Aug 3, 2025 at 3:51 AM
STEVE W.
  • 15,387 POSTS
Any good shop that you trust should be able to look it over and give you a solution, It might just be one with a "touchy" pedal. I get an Equinox in now and then like that, bone stock but if you breath on the pedal the engine revs up!
Aug 3, 2025 at 3:58 AM
WALTBK
Thanks Steve. I'm in Haverhill (Northeastern) Massachusetts. Any chance you could recommend a shop in my area? I'm tired of getting blank stares...
Aug 3, 2025 at 9:41 PM
STEVE W.
  • 15,387 POSTS
Don't really know of a shop out that way that does automotive diagnostics, there are quite a few parts cannon shops though. You might ask on facebook or other social media, or see if you can get Mustie1 on you tube to give you a pointer, he is a decent guy who is in Plaistow, he might know of a good independent shop.
Aug 4, 2025 at 2:12 AM
