Code P0753 X2, where is the shift solenoid located?
24,264,200 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
AMANDA ARMSTRONG
  • 13 POSTS
Can't find the shift solenoid.
May 16, 2023 at 2:47 AM
  • 55,770 POSTS
code P0753 refers to a malfunction in Shift Solenoid A Electrical.
May 16, 2023 at 5:38 AM
AMANDA ARMSTRONG
  • 13 POSTS
I have removed the transmission pan and the filter but I still haven't seen the solenoid.
May 16, 2023 at 7:07 AM
  • 55,770 POSTS
Can you upload an image of what you are seeing so I can help? The code is for the electrical connection so the solenoid might be shorted which is common.
May 17, 2023 at 1:58 AM
AMANDA ARMSTRONG
  • 13 POSTS
Yeah, I can do that but let me wake up.
May 17, 2023 at 3:45 AM
  • 55,770 POSTS
no problem.
May 18, 2023 at 4:26 AM
AMANDA ARMSTRONG
  • 13 POSTS
This is with the transmission pan and filter off.
May 18, 2023 at 10:09 AM
  • 55,770 POSTS
Sorry the pan you need to remove is on the side of the transmission to replace the shift solenoids. Here are the location and instructions in the images below. Check out the images (below). Please let us know what happens.
May 19, 2023 at 5:07 AM
AMANDA ARMSTRONG
  • 13 POSTS
So, do I have to drop the transmission to get to the shift solenoid?
Jun 3, 2023 at 11:03 AM
  • 55,770 POSTS
It looks like it. You may be able to remove the transmission and maybe an engine mount to lower it enough to remove the side pan. Here is how the job is done. Check out the images (below). Please let us know what happens.
Jun 5, 2023 at 2:22 AM
AMANDA ARMSTRONG
  • 13 POSTS
I just found out that the paperwork on the Grand Prix is wrong. It is a 1999 Pontiac Grand Prix. Any chance you could tell me where the shift solenoid is located still?
Jun 8, 2023 at 7:06 AM
  • 55,770 POSTS
No problem, it looks like it is in the same place. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Jun 9, 2023 at 3:54 AM
