Is thread sealer used on coil tower cover bolts and or cam cover bolts
156,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROGERMM65
  • 50 POSTS
Do i use thread sealer on coil tower cover bolts and or cam cover bolts?
May 11, 2020 at 2:51 AM
Good morning,
No, do not use thread sealer at all. It is not recommended or required for this repair.
Just torque the bolts to the proper torque and you are good. The torque is 10 ft. pounds.
May 11, 2020 at 3:01 AM
ROGERMM65
  • 50 POSTS
10 ft pounds of torque = ? snug tight , medium tight or super tight?
May 11, 2020 at 1:37 PM
10 foot pounds is around medium tight.
May 11, 2020 at 2:15 PM
ROGERMM65
  • 50 POSTS
Okay to spray cams with penetrating oil before new gaskets and recovering? Thanks again .
May 28, 2020 at 2:49 PM
I would take a quart of engine oil and pour it over the cams.
That is the best lubricant.
May 28, 2020 at 8:59 PM
