Throttle bottle body
2006 LEXUS IS 250
100 MILES • 0.6L • 2WD
JEAN JACKSON
  • 7 POSTS
My throttle bottle body is gone. can I purchase a used one an will it work?
Jan 29, 2019 at 5:59 AM
Good evening,
Yes, you can replace it with used but you are taking a chance if the used one is no good.
I attached a picture of one available from rockauto. It is pricey but so are all the parts for a Lexus.
Procedure
REMOVAL
1. REMOVE COOL AIR INTAKE DUCT SEAL
2. DRAIN ENGINE COOLANT
3. REMOVE ENGINE ROOM SIDE COVER RH
4. REMOVE V-BANK COVER SUB-ASSEMBLY
5. DISCONNECT NO. 2 VENTILATION HOSE
a. Disconnect the ventilation hose from the cylinder head.
6. REMOVE AIR CLEANER CAP WITH AIR CLEANER HOSE
a. Disconnect the MAF meter connector.
b. Disconnect the clamp from the air cleaner.
c. Disconnect the VSV hose.
d. Disconnect the 4 clamps.
e. Remove the hose clamp and air cleaner cap with air cleaner hose.
7. REMOVE THROTTLE BODY
a. Disconnect the throttle motor connector.
b. Remove the 4 bolts and disconnect the throttle body from the intake air surge tank.
Jan 29, 2019 at 7:40 AM
JEAN JACKSON
  • 7 POSTS
So how much is a new one? I'm looking for one 2006 Lexus is 250.
Jan 29, 2019 at 12:40 PM
JEAN JACKSON
  • 7 POSTS
You know somewhere that has them or put them on to?
Jan 29, 2019 at 12:42 PM
I sent you a link for the throttle body. The price was around $400.00.
A new one from Lexus is around $700.00 to $800.00.
I would call around your area and see if someone can help you.
Jan 29, 2019 at 7:12 PM
JEAN JACKSON
  • 7 POSTS
Jan 31, 2019 at 10:54 AM
You are welcome.
Always glad to help.
Jan 31, 2019 at 10:56 AM
JEAN JACKSON
  • 7 POSTS
I'm going to get a diagnostic on it and make sure that what wrong and go from there. may have to set up a month. I just don't want anybody working one guy that work on Lexus say he been working on Lexus and he have never had to replace this part on Lexus. he suggested I get a diagnostic before I do any thing. thank you again
Jan 31, 2019 at 2:56 PM
Good idea.
Hope it works out for you.
Jan 31, 2019 at 6:00 PM
