Code c1155 wheel sensor failure
145,564 MILES • 2.5L • 6 CYL • 4WD • AUTOMATIC
PRRYPERRYS
  • 150 POSTS
Hey my friend, I am still getting code c1155 saying wheel sensor. I changed the sensor on front right and left. I change the harnessed on left and when I connect the tester I do get a little power, but I do not know what it is supposed to read period or what to set the tester to.
Oct 14, 2018 at 11:00 AM
  • 110,248 POSTS
Hi Kenny, and welcome back. I did a little research and found a technical service bulletin (TSB) for this issue as well as the diagnostic guidelines. Please read through this and follow the steps. Since it is listed as a TSB, there have been issues related to what you are experiencing. Also, pay attention to the drive cycle needed after repairs for the light to go out.
______________________________________
ABS/TCS - WHEEL SPEED SENSOR DIAGNOSTICS
NUMBER
XT100-016
MODEL
X-TYPE
DATE
07 Dec 2006
SECTION: 100-00 - GENERAL INFORMATION
Wheel Speed Sensor Concerns Diagnosis
AFFECTED VEHICLE RANGE:
X-TYPE
VIN:
C00001 onwards
Model Year:
2002 onwards
CONDITION SUMMARY:
DIAGNOSTIC GUIDANCE FOR WHEEL SPEED SENSOR FAULTS
Situation:
This bulletin has been issued to provide diagnostic guidance for wheel speed sensor faults.
Action:
Should a wheel speed sensor fault arise, refer to the Repair Procedure detailed in this bulletin to resolve the concern.
PARTS:
No parts provided for this bulletin. Diagnostic information only.
WARRANTY:
No warranty necessary for this bulletin. Diagnostic information only. Normal warranty policy and procedures apply.
REPAIR PROCEDURE
CLASSIFICATION OF WHEEL SPEED SENSOR FAULTS
NOTE:
Wheel speed sensor faults are classified as either "electrical faults" or "signal faults" and will indicate a potential problem as follows:
^ Electrical faults indicate a problem with the wheel speed sensor electrical circuit. The problem may be with the sensor, the control module or the wiring between the speed sensor and the control module. Warranty analysis indicates that the wiring is the most likely source of wheel speed sensor electrical faults.
^ Signal faults indicate that there is no detectable fault with the wheel speed sensor circuit but there is an abnormality with the signal from the sensor. The abnormality may be in the form of an implausible change in signal level, as a step or a spike, or it may be that it is at an implausible level compared to other wheel speed signals, for example, one signal may remain at zero while the others show a normal road speed.
NOTE:
After fixing some wheel speed sensor faults, it will be necessary to drive the vehicle above a speed of 10 mph (16 kph) in order to extinguish the ABS warning lamp.
NOTE:
A Midtronics battery charger PSC550 must be connected to the vehicle battery during diagnostic sessions.
1. Connect the diagnostic equipment to the vehicle and begin a WDS or IDS session.
NOTE:
DTCs and snap shot data should be noted at all stages during the diagnosis. This information will be needed in the event further assistance is requested from Jaguar Technical Helpline.
2. Note DTCs and collect snap shot data.
NOTE:
Where there is a combination of electrical faults and signal faults, the electrical faults should be corrected before investigating the signal faults. Correcting the electrical fault may also resolve a signal fault.
3. If no 'electrical faults' have been logged, proceed to the SIGNAL FAULT DIAGNOSTIC GUIDELINES section of this bulletin.
ELECTRICAL FAULT DIAGNOSTIC GUIDELINES
NOTE:
Wheel speed sensor faults may be either "permanent" or "intermittent". Intermittent faults can be difficult to find but are usually caused by wiring or connector issues. If a wheel speed sensor Anti-lock Braking System (ABS)/Dynamic Stability Control (DSC) module fault is intermittent, it is highly unlikely that the cause of the fault is the ABS/DSC module.
A fault may be determined to be either "permanent" or "intermittent" by using the diagnostic tool to clear the Diagnostic Trouble Code (DTC) and carrying out an ignition reset.
1. Determine if a DTC is 'permanent' or 'intermittent' as follows:
^ Clear the DTC.
^ Carry out an ignition reset.
^ If the fault immediately returns on the next ignition reset, and if it is the only fault that returns, the fault is 'permanent' and the control module should be replaced.
NOTE:
Wiring damage includes any signs of fatigue, rubbing, stretching or brakes. Damage to the wire insulation only is included as this can allow water into the wheel speed sensor head.
2. Carry out a detailed visual inspection of the wheel speed sensor cable from the point it connects to the sensor to the point it connects to the body or link harness.
3. If any damage is found, replace the wiring and sensor.
4. Disconnect each connector between the ABS/DSC module and the suspect wheel speed sensor and perform the following checks:
^ Check connectors for signs of pin corrosion, water ingress or damage.
^ Check that the pins are not bent or backing out.
^ Lightly pull the wheel speed sensor wires from the back of each connector to ensure they are securely crimped to the pins.
5. Reconnect all connectors and check to see if the DTC will clear.
6. Verify that a wheel speed sensor is working correctly by performing the following:
^ Disconnect the suspect sensor and a non-faulting sensor from respective wheels.
^ Electrically connect the suspect sensor to the wheel of the non-faulting sensor.
^ Carry out an ignition cycle (ignition on/off) and use the diagnostic tool to read the fault memory.
^ If an 'electrical fault' DTC has been logged for the wheel to which the suspect sensor has been connected, the sensor should be replaced.
7. Disconnect the ABS/DSC module connector and the connector closest to the wheel speed sensor.
8. Carry out wiring integrity tests (continuity, short-circuit, short-to-ground and short-to-power) on the wiring between the two connectors.
9. If a fault is 'intermittent', 'wiggle' the wires/cable harnesses, where they are accessible, and search for intermittent breaks/shorts.
10. If no faults were found and the wheel speed sensor fault was determined to be 'permanent' in step 1, the ABS/DSC module should be replaced.
11. If the fault is 'intermittent' and the wheel speed sensor was verified to be OK in Step 6, replace connector pins and link harnesses, where possible, in the wheel speed sensor circuit, as the likely root cause of the fault is an intermittent wiring or connector fault.
NOTE:
Wheel speed sensor signal faults can be caused by sensor installation issues, wiring issues, or even vehicle behavior.
NOTE:
A wheel speed sensor signal fault will clear and not return after a normal test drive if the fault was a result of either of the following situations:
^ Individual wheels or pairs of wheels having been rotated independently of the others, such as when the wheels have been driven while the vehicle is on a wheels-free ramp.
^ A loss of traction on one or more wheels for extended periods.
1. Check that the vehicle has the correct wheel and tire sizes and that the tires are properly inflated.
2. If any discrepancies were found, correct and re-test.
3. Visually inspect to ensure that the sensor is correctly installed and seated.
4. If the encoder ring is visible, check that it is clean and that none of the teeth are damaged.
5. If the encoder ring is installed in the wheel bearing, and there is no excessive play in the bearing, remove the bearing and check the encoder ring for contamination or damage.
6. Check the sensor lead for any signs of damage to the outer insulation.
7. Check the sensor lead connector for damage or any signs of water ingress.
8. If any faults were found, correct and re-test.
9. If the diagnostic tool supports a data logging application, perform the following:
Set up to monitor the output from all four wheel speed sensors during a road test.
NOTE:
As the vehicle speed increases from stand still, all four signals should rise simultaneously and show the same output, within an average of +/- 1.2 mph (+/- 2 kph). There should not be any random or regular signal spikes or deviations on individual signals.
^ Test drive the vehicle slowly at approximately 10 mph (16 kph) in a straight line on a smooth road.
^ Check for any random spikes/deviations occurring on any individual signal that will indicate an electrical fault.
^ Check for any regular spikes/deviations occurring on any individual signal that will indicate a problem with the sensor encoder ring.
10. Perform the following integrity checks on the wiring between the sensor connector and the control module connector:
^ Check for shorts to power or ground.
^ Check for signs of corrosion or water ingress into the connectors.
^ Check for any cuts or abrasions in the wiring insulation, where possible.
11. Disconnect and re-connect all connectors between the ABS/DSC module and the suspect wheel speed sensor and check to see if the DTC clears.
12. Determine if the root cause of the problem is the sensor as follows:
^ Swap the left-hand and right-hand sensors on an axle.
^ Test drive the vehicle above a speed of 10 mph (16 kph).
^ If the fault moves with the sensor, the sensor is faulty.
13. If no faults have been found, clear all DTCs and take the vehicle on a test drive of at least 10 miles (16km) above a speed of 10 mph (16 kph).
14. If there are no faults, the vehicle can be returned to the customer.
Let me know if this helps.
May 23, 2021 at 5:59 AM
PRRYPERRYS
  • 150 POSTS
Hey Joe my friend, thank you very much. I may just leave it in the garage for now and work on it next summer. it's not my regular car just my favorite car. I have a question I change the front right axle and after I changed it. the brake caliber the thing that hold the brake pad in place that's not the caliber right I forget what it's called but it started grinding the Rotor I thought it was a bad rotor. then I change the rotor and it still grinding after driving about 4 to 5 miles. Do you think maybe I put the wrong drive axle in and I also change the control arm. That's when I started having the grounding problem after changing the control arm and drive axle. Well my friend did it so maybe he did something wrong. Kenny
  • 110,248 POSTS
Welcome back, Kenny:
Are you referring to the caliper mount? The part which the caliper bolts to? If so, my first concern is the wheel hub bearing wasn't properly tightened. I can also say that the two axles (half shafts) are different lengths. Is it possible the wrong one was installed?
If you lift that wheel off the ground, place your hands at 3 and 9 positions. See if there is play back and forth. Do the same at the 6 and 12 positions. Also, see if there is any in and outward movement in the wheel. Also, confirm with your friend that he properly torqued the hub bearing.
PRRYPERRYS
  • 150 POSTS
Hey Joe, thank you very much. Yes exactly that's what I was referring to. And he did not use a torque wrench when tightening any of the bolts what should the hub bolt be torque too. And I will Jack the car up tomorrow when I come from work and see if I have any moving from 9 to 3 and from 12 to 6 I know for a fact he never torque the hub bearing because he never use a torque wrench and I offered him the torque wrench he said he know he don't need it.. maybe I need to find someone else to work on my car because I had already read it and it said pretty much everything you do on this car has to be torqued.
  • 110,248 POSTS
Here are the hub nut torque specs:
Tightening Specifications
Wheel Hub Nut .................... 330 Nm or 243 ft/lbs
That's tight!!!
If you want the directions for the procedure, let me know.
PRRYPERRYS
  • 150 POSTS
Thank you Joe that is cool. I will try tomorrow when I get out of work and I will let you know the outcome. Thank you, Kenny
May 23, 2021 at 6:00 AM
  • 110,248 POSTS
You are welcome. Take care.
PRRYPERRYS
  • 150 POSTS
Hey Joe, hope all is well. It was not the axle bolt. It is tight. I notice when car is on lift front two tires are very hard to turn by hand. They should turn freely right. What could that be? Kenny
  • 110,248 POSTS
Welcome back:
Honestly, it is normal for there to be tension when turning the wheels. You have to turn all steering components as well as the rack and pinion. If it is nearly impossible to turn, that is a different story.
PRRYPERRYS
  • 150 POSTS
I am a little confused because the back two wheels you can spin them with one hand. However, it takes two hands to force the front two to spin.
  • 110,248 POSTS
If you find the wheels are difficult to spin, there is a chance the calipers are hanging up or the bearing torque is too high. You did reconfirm the hub bolt torque, correct?
PRRYPERRYS
  • 150 POSTS
Oh, I forgot to check the axle nut torque I just tighten it. I will check that today. Thank you. Kenny
  • 110,248 POSTS
If they are over tightened, it will cause a drag. Let me know what you find.
PRRYPERRYS
  • 150 POSTS
Hey Joe, thank you. Car all set axle bolt was to tight. Kenny
  • 110,248 POSTS
Glad to hear you got it fixed. If they were over tight, it would have destroyed the bearing.
Take care, Kenny. Let me know if you have questions in the future.
PRRYPERRYS
  • 150 POSTS
Okay thank you my friend. I will check those bearings. Kenny
  • 110,248 POSTS
Happy to help.
  • 110,248 POSTS
You are very welcome.
PRRYPERRYS
  • 150 POSTS
Thanks Joe have a blessed night. We will talk soon.
PRRYPERRYS
  • 150 POSTS
Hey Joe, hope all is well. Well I got to the bottom of the well being too tight it was the axle nut. Thank you and overheating was the cooling fan. Now I have another problem when I go to unlock my door with remote or key it does not open front two doors 99% of the time from the outside latch does not open the door although you can see the lock unlock from the inside. The back two doors work fine no problems
RENEE L
  • 1,260 POSTS
Hello PRRYPERRYS@AOL.COM,
Your issue with your door not unlocking with remote is an entirely different issue in order for the site to properly index your question can you please post it in a new question? Make sure you are logged into the site first.
Please post your new question here: https://www.2carpros.com/questions/new
Thank you,
Renee
Admin
