leaking transmission fluid
200,000 MILES • AUTOMATIC
ELISHA YOUNGBLOOD
This is a used van. I just got the van serviced around the first of June and they filled the transmission fluid but it seemed low again a week later. Seems to be leaking transmission fluid how do I fix it?
Jun 26, 2017 at 1:27 AM
  • 31,937 POSTS
You first need to identify where the leak is coming from, clean down the transmission and fill to correct level, go for a drive and re check for leaks, check pan gasket drive shaft seals and check for any leak around bottom of bell housing and engine, let me know what you find.
Jun 27, 2017 at 7:31 PM
