Thermostat locations?
220,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
CURSHANDA THORNTON
Left top of radiator coolant tank.
Aug 12, 2025 at 7:03 AM
  • 55,694 POSTS
I assume you want the location of the cooling system thermostat correct? they don't make a 2.4 liter in 2017 so here is the location for the 2.0 liter turbo which is right be the water pump. Check out the images (below). Let us know if you need anything else.
Aug 13, 2025 at 4:00 AM
