Thermostat removal, is sealant required
100,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
JUAN L. DIAZ
Car is overheating. I want to remove the thermostat. I can get the thermostat out but I need to know if I need the use any kind of sealant when I put everything else (housing, etc.) back together?
Jun 23, 2018 at 3:56 AM
STEVE W.
  • 15,418 POSTS
Removing the thermostat is not going to stop it from overheating. You need to determine what is causing the overheating. What was the engine doing prior to overheating? Was it run hot? What are you calling overheating? Coolant boiling over or? Are the cooling fans working? When does it overheat, idle or driving down the road?
Sep 24, 2020 at 3:06 AM
