A couple weeks ago my car's temperature got really low then check engine light came on. I took it to AutoZone. Used a code reader it said thermostat, but after a day the temperature went back to normal and engine light disappeared. For a week it was normal. Then today the temperature went back down cold again, you can hear the fan motor going but for some reason it shut off the air compressor, so A/C was not blowing out cold air. No engine light, Then the temperature went back to normal, and the air compressor was working again. I didn't understand if it might be the thermostat why would it shut off the air compressor? That's why I was wondering if it might be something electrical going? Appreciate any help.
Aug 11, 2022 at 8:46 AM
