Where is the Thermostat located?
156 MILES • 2.7L • V6 • AUTOMATIC
YOUNG348
  • 21 POSTS
Hi, I am trying to find where the thermostat is located on my vehicle. I have Googled it and cannot find anything on it.
Sep 8, 2022 at 12:09 PM
STEVE W.
  • 15,398 POSTS
The 2.7 thermostat is located on the side of the block right above the A/C compressor. To get to it you need to remove the drive belt and then put the vehicle in the air and unbolt the compressor to move it out of the way to get to the thermostat housing bolts. With it out of the way you remove the housing and reverse the process to install the new one, make sure the purge valve is at the top.
Sep 8, 2022 at 6:18 PM
YOUNG348
  • 21 POSTS
Thank you so much Steve W. I truly appreciate it. I also have one more question, I have just replaced the coolant temp sensor and seems to have stopped the overheating and the coolant empty, but it still seems to read over the normal temperature every now and then while driving and then when applying acceleration will go down to normal level again. Do you have any ideas what might be going on? The coolant level remains the same though now. Thank you for your time.
Sep 10, 2022 at 7:01 PM
STEVE W.
  • 15,398 POSTS
If you mean that you can be driving down a highway for a while, then come into a town and need to go slower and the temperature goes up a bit, then when you get back on the open road it goes back to normal, that is normal. The reason is the airflow through the radiator is what removes the heat from the cooling system, so out in open air the speed of the car moves a lot of air through the radiator. When you get into traffic or stop and go driving like in town that airflow drops a lot and you become dependent on the cooling fans to move air. However, on most vehicles those fans turn on at a higher temperature than many think, most are at or over the boiling point of plain water. So, if you are driving on an open road and see a temperature of say 199-200 normally then you get into town, and it moves up to 210-220 or so, that is normal. If on the other hand it climbs too much higher like 240+ or higher then you will want to check the radiator for blockage. Dirt, bugs damage to it or the A/C condenser in front of it can lead to higher operating temperature.
Sep 11, 2022 at 1:44 AM
