Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Pathfinder
Engine Cooling
Thermostat
Where is the thermostat located?
2015 NISSAN PATHFINDER
109,876 MILES • 3.8L • 6 CYL • 4WD
ANDRIN ATEM
MEMBER
Hi, please can you help me out with the location of the thermostat, a diagram of DIY. Thanks.
Nov 11, 2021 at 5:46 PM
Experienced Mechanic
Good morning,
I attached the picture of the location for you of the location.
If you remove the lower hose, there is a 3-bolt housing by the outlet that contains the thermostat.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Images (Click to enlarge)
Nov 11, 2021 at 6:32 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
