What is the thermostat housing bolt size?
305,000 MILES • 2.2L • 4WD • AUTOMATIC
TYLER TACHELL
Hey there, I have the vehicle listed above Outback and I need to know the bolt size for the thermostat housing.
Oct 30, 2023 at 11:33 AM
  • 110,251 POSTS
Our manuals don't indicate a size. I can tell you that the threaded diameter is usually either 6mm or 8mm, but I don't have the thread pitch or length.
I attached what I believe is the bolt you need below. It includes the OEM part number, but please confirm that is correct for your vehicle.
I hope in some way this helps.
Oct 30, 2023 at 12:48 PM
