A GASKET WOULD BE THE WAY TO GO
ON FLAT PAPER GASKETS I COAT BOTH SIDES WITH "INDIAN HEAD" OR "GASKET SHELLAC" (SAME THING, 1st ONE IS A BRAND NAME)
GIVING YOU A PIC AT THE BOTTOM, USING IT ON MY JEEP'S TIMING CHAIN COVER GASKET
SILICONE OR RVT USUALLY GETS OVER USED ON GASKETS AND THE "EXTRA" GETS INTO THE ENGINE AND MAY CAUSE PROBLEMS (IT DOES HAVE IT'S PLACE THOUGH)
IF YOU WANNA SEE WHAT HAPPENS WITH OVER USE. SEE MY ANSWERS IN THIS LINK
https://www.2carpros.com/questions/1992-jeep-wrangler-40l-squealing-noise-coming-from-transmission-or-transfercase
RULE OF THUMB WITH YOUR QUESTION- IF IT HAD A GASKET TO BEGIN WITH, USE ONE BACK!
I HOPE THIS HELPS
THE MEDIC
Images (Click to enlarge)
Jan 18, 2016 at 11:03 AM
