Just run water from a sink on it to clean any debris and immediately install it back into the vehicle?
Nov 16, 2021 at 11:50 PM
✓Experienced Mechanic
Good morning again,
No, cleaning it does nothing. You already have it out and it would not make sense to not replace it with a new one. Whatever issue you had prior to removing it will be there after you install it if it was the thermostat.
