Can I take the thermostat and clean it with water?
127,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
IMAGING
  • 151 POSTS
Just run water from a sink on it to clean any debris and immediately install it back into the vehicle?
Nov 16, 2021 at 11:50 PM
Good morning again,
No, cleaning it does nothing. You already have it out and it would not make sense to not replace it with a new one. Whatever issue you had prior to removing it will be there after you install it if it was the thermostat.
Nov 17, 2021 at 12:15 AM
