Thermostat bolt removal issue?
118,000 MILES • 2WD • AUTOMATIC
DANIEL NELSON2
  • 44 POSTS
I need help getting off the bolts that hold the thermostat the bottom one in particular.
Nov 12, 2023 at 3:24 AM
  • 110,248 POSTS
I need to know which engine you have. Is it a 3.4L or a 3.8L? (see pic below).
Let me know. If it is the 3.4, you will need to remove the crossover pipe.
Take care and I'll watch for your reply.
See pic below.
Nov 12, 2023 at 12:52 PM
DANIEL NELSON2
  • 44 POSTS
It is the 3.4.
Nov 14, 2023 at 1:19 AM
DANIEL NELSON2
  • 44 POSTS
How do I take off the crossover pipe?
Nov 14, 2023 at 1:20 AM
  • 110,248 POSTS
Yep, you have to remove the exhaust cross-over pipe to access the thermostat. I attached the directions below.
The first four pics are for thermostat replacement. In pic 2, I highlighted what needs to be removed. The cross-over pipe directions start with pic 5.
Let me know if this helps.
Nov 14, 2023 at 6:52 AM
DANIEL NELSON2
  • 44 POSTS
What size are the bolts because I lost one?
Nov 14, 2023 at 8:23 AM
  • 110,248 POSTS
That type of information isn't provided in my manual. Is it possible to remove one of the other two and have it sized for replacement?
Nov 14, 2023 at 8:30 AM
