Thermostat and cooling issues
2007 CHRYSLER PT CRUISER
113,000 MILES • AUTOMATIC
SBOHARA
I have a red oil light that came on, a check engine and the thermostat gauge is running hot after being on not even 10 minutes. just had the fan relays fixed, before that I had the thermostat and the housing replaced and the radiator. Not sure if it’s a sensor or actually overheating.
Dec 6, 2019 at 7:26 AM
So we need to start with checking codes to see if that points us to a possible cause. If not, then we need to use an infrared thermometer to determine if the engine is overheating. Check the hoses and around the engine block. It should not be more than about 210 degrees. If it is then the engine is actually overheating.
Let me know what the codes are and we can go from there. Thanks
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
https://youtu.be/d5d0QXJBQ7A
Dec 6, 2019 at 6:23 PM
