Installing a new thermostat does the coolant need to be drained?
165,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JUSTANJ57
Do i drain the coolant before installing the new thermostat?
Oct 24, 2024 at 5:59 PM
  • 55,746 POSTS
Yes you do, some don't but it makes a mess, and it is better for the gasket sealer to dry without contamination. Here is how to drain the coolant and how to change out the thermostat in case you need it. Check out the images (below). Let us know if you need anything else.
Oct 25, 2024 at 4:45 AM
