Thermostat issue Code P0128
80,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
PETE CUNNINGHAM
Here is the info I have. Wondering what I need to do to fix this.
Dec 13, 2021 at 2:49 AM
SQM
  • 6,383 POSTS
The code P0128 can be triggered by a faulty thermostat, low coolant level or other coolant system issues.
What drivability issues are you experiencing? Is it running cooler than it should?
I have attached the troubleshooting steps for code P0128 below. Go through those steps and it can help to figure out the issue.
Dec 13, 2021 at 3:14 AM
PETE CUNNINGHAM
Yes, it's running cool.
Dec 13, 2021 at 3:33 AM
SQM
  • 6,383 POSTS
It could be do to the thermostat opening too soon or just stuck open.
Go through the troubleshooting guide above. Let me know what you find.
Dec 13, 2021 at 3:59 AM
SQM
  • 6,383 POSTS
I have attached the thermostat replacement procedure below.
Let me know of any questions.
Dec 13, 2021 at 11:48 AM
PETE CUNNINGHAM
I replaced the thermostat and problem solved..thank you !!
Dec 16, 2021 at 4:19 AM
SQM
  • 6,383 POSTS
You are welcome. That is great news.
Dec 16, 2021 at 4:50 AM
