How do you change and replace the thermostat in my car? Step by step process would be nice, thank you!
Mar 24, 2017 at 11:01 AM
✓Experienced Mechanic
Hello, DK
You must first start by draining the coolant. Here is a guide and some diagram that can help you get the job done. You will need to bleed the system using the bleeder on the thermostat housing once the job is complete.
