if it is a bad thermostat it will overheat with in about five minutes. check coolant level then have it pressure checked for head gasket leakage.
Nov 8, 2016 at 5:19 AM
JOHNNY G.JR
✓Experienced Mechanic
See if there are air bubbles inside of radiator with engine running,sign of defective head gasket.
Nov 8, 2016 at 12:12 PM
ANNA DAVIDSON
MEMBER
I drove it up to O'Reilly's auto parts and had them do a diagnostic test and they wrote down four codes and that was that. Not sure if I am supposed to Google the codes or not.
Nov 8, 2016 at 12:42 PM
HMAC300
just give us the codes we can tell you what the problems are.
