Where is the thermostat located?
21,000 MILES • 2.2L • 2WD • AUTOMATIC
DEMETRIUS TAYLOR
Where is my thermostat located on the car listed above?
Jun 29, 2021 at 12:22 PM
  • 110,248 POSTS
You need to remove the intake manifold to access it. To get you started, here is a link that shows in general how it's done:
If you look at the attachments below, they provide the directions specific to your vehicle for thermostat replacement. Also, I included the bleeding procedures. Make sure not to mix the original dex-cool coolant from GM with other types unless it is a universal type indicating it can be used with Dex-cool. This is very important.
The only way to replace the coolant with a different type is to completely remove the old coolant from the entire system, flush it, and then install something different.
Jun 29, 2021 at 1:27 PM
