Are there any brands of A/C compressors that can be used on a Mercedes Benz?
2008 MERCEDES BENZ R350
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
SILVAELISEU
MEMBER
1 POST
Someone told me if I don't use an exact brand. The computer is going to show that after the repair is done. Is this right?
Nov 28, 2023 at 6:50 AM
✓Experienced Mechanic
If you purchase a direct replacement compressor, it should be fine. However, there are different compressors based on the system and production dates.
I attached a pic below which provides the OEM part numbers based on need. If you purchase one, just make sure it replaces the part number indicated.
joe
See pic below.
Image (Click to enlarge)
Nov 28, 2023 at 12:53 PM
