theft warning
2001 TOYOTA CAMRY
156,024 MILES • V6 • AUTOMATIC
IKSON
I found a device (theft warning Toyota 89730-AA010) in my car while cleaning it. I want to know where it is located and how to install back? Thanks
Oct 13, 2017 at 10:13 PM
  • 31,937 POSTS
It has probably been disconnected due to a problem, with out seeing what else has been disconnected or removed i cannot really say. possibly a mechanic having a first hand look can tell you if the system has been terminated permanently. there will be some tell tail signs of alterations under the dash, but really what is needed is a first hand inspection to see what is going on.
Oct 14, 2017 at 2:48 PM
IKSON
Okay, but where is it located?
Oct 15, 2017 at 2:28 AM
  • 31,937 POSTS
on a left hand drive car it should be up behind the dash in behind the glove box closer to the centre console, but thinking about this, if the module is disconnected the car wont start...... it should also be linked into central locking, if this works there must be a module installed.i am wondering if it was replaced and someone forgot to take it out of the car? i have seen this before, replaced modules replaced and been left behind by mistake.
Oct 15, 2017 at 10:01 PM
