Anti theft light flashing after replacing key
300,000 MILES • 1.4L • V8 • 4WD • AUTOMATIC
RONNIE FONTANA
lost the key had a new one made and programed. it didn't program so replaced elecring on the ignition. anti theft still flashing.
Nov 28, 2020 at 7:18 PM
  • 110,246 POSTS
Here are the directions for reprogramming the new key without a scan tool. Take a look through it and let me know if it is what you have already done. Also, I'm not sure what you mean by elecring. I attached a pic below. Do you see the part that was replaced?
______________________________________
KEY PROGRAMMING - NEW KEY (Without Diagnostic Tool)
NOTE: Before starting this procedure, make sure the key(s) your want to program have the correct mechanical cut.
1. Insert the nonprogrammed key in the ignition and turn to RUN.
2. THEFT indicator proves out after 2 seconds and then flashes rapidly.
3. After 15 minutes of flashing, the THEFT indicator will stop flashing.
4. Within 5 minutes after the THEFT indicator has stopped flashing, turn the ignition key to OFF and back to RUN.
5. THEFT indicator proves out after 2 seconds and then flashes rapidly.
6. After 15 minutes of flashing, the THEFT indicator will stop flashing.
7. Within 4 minutes after the THEFT indicator has stopped flashing, turn the ignition key to OFF and back to RUN.
8. After 15 minutes of flashing the THEFT indicator will stop flashing.
9. All originally programmed keys are now erased, and the key in the ignition is now programmed.
10.Additional keys may be programmed using the Key Programming - Spare Key Procedure.
Let me know if that helps.
Nov 29, 2020 at 12:16 PM
RONNIE FONTANA
thank you.
Dec 1, 2020 at 11:31 AM
  • 110,246 POSTS
You are very welcome. Did it help?
Dec 1, 2020 at 11:32 AM
RONNIE FONTANA
The theft light does not flash for 15 minutes it flashes for about a minute and a half. oh, it was the transponder that i replaced with the ignition relays and fuses are all good.
Dec 2, 2020 at 6:09 AM
  • 110,246 POSTS
Take a look at the attached list of possible causes.
The passive vehicle protection system will be activated and will disable the vehicle from starting if any of the following actions occur:
1. Damaged encoded key.
2. Unprogrammed key.
3. Non-encoded key (key has no electronics).
4. Wiring concern.
S. Transceiver concern.
6. Control module concern.
7. Module Communications Network concern.
Because there are several different possible issues, we really need to scan the computer for codes. The new transceiver could be bad, not recognized, or simply not communicating with the PCM.
Here is a link that shows how it's done:
Let me know if that is something you can do or have done.
Dec 2, 2020 at 10:05 AM
