The windshield wiper is not working
3.0L • 4 CYL • 2WD • AUTOMATIC
STACIE5416
I was trying to locate the relay switch I have checked the fire to the motor there is fire to the motor and there is fire to the switch inside, but the wiper still will not work.
Nov 1, 2014 at 5:43 AM
  • 110,248 POSTS
If you have power to the wiper motor, either the motor is bad or there is no ground. Check to make sure there is a good ground first. If there is and you have power to it, then the motor is bad.
Nov 1, 2014 at 11:59 AM
