This van has always started! It has duel tanks. I was driving the van and it ran out of gas. I put five gallons in each tank. Now, I cannot get gas to the carburetor. It fires right up and runs for a few seconds when I use starter fluid or gas directly in the carburetor. Is there a filter along the gas line? The tank switch (on the frame) clicks when I change from front to rear. The mechanical fuel pump is new, as is the filter on the two barrel carburetor. What could this problem be? Thank you!
Sep 28, 2017 at 4:20 AM
