The trucks shuts off
1999 GMC C1500
2,456,675 MILES • 5.7L • 5 CYL • 2WD • AUTOMATIC
ROBERTA3
  • 9 POSTS
I just changed the thermostat and now the truck just shuts off. all the gauges went back to normal and started working, I drove it to my house. now I started up and it just shuts off.
Feb 8, 2020 at 10:06 AM
  • 110,241 POSTS
When the vehicle stalls after starting, are you able to start it right back up? Also, when you replaced the thermostat, did was there a lot of coolant spilled on the engine? Is the check engine light staying on all the time or does it shut off after a few seconds?
Let me know,
Feb 8, 2020 at 11:02 AM
ROBERTA3
  • 9 POSTS
Yes, I can start it up right after it shuts off. Yes, a lot of coolant spilled from the on the engine then I took off to the whole house right now it just starts up and it doesn't run. it's just I'm able just to start it up and it doesn't stay long it just doesn't stay on when I start up.
Feb 8, 2020 at 11:05 AM
  • 110,241 POSTS
I'm questioning if something such as a crankshaft position sensor was damaged by coolant. Are there any diagnostic trouble codes? Have you tried scanning the computer? I suspect it is something simple because the problem started after the work. However, I don't want to recommend parts without being somewhat certain. Also, is the security light (anti theft) staying on?
Feb 8, 2020 at 12:07 PM
ROBERTA3
  • 9 POSTS
When I started it again it started to wind it like a circuit short thin the engine got stronger, but it was winding I let it run for about a couple of seconds then I shut it off. it might be the sensor the reason it won't stay on but it sound like some kind of connection like either the spark plug wires made it . But if not that's sensor then what else could it might be? I don't know. I thank you very much though. I really don't know what else could the problem I have been. thanks
Feb 8, 2020 at 1:41 PM
  • 110,241 POSTS
Is it possible for you to record what you heard with your phone and upload it for me to hear?
Feb 8, 2020 at 1:43 PM
ROBERTA3
  • 9 POSTS
I was going to try to shut it off at one more time on Sunday night and then try to make a run for it to catch the mechanic in the morning. it sounds like the was getting a little better. I'm just really scared to shut it back on.
Feb 8, 2020 at 1:50 PM
ROBERTA3
  • 9 POSTS
It's like when I leave it turned off for a long while it jump-starts back back on, but then don't want to mess around with it it becomes an issue like a problem and it doesn't want to do anything. it just doesn't start. it won't start and I'm all the way out of the country now and I really don't want to get stuck out this way.
Feb 8, 2020 at 1:51 PM
ROBERTA3
  • 9 POSTS
I'm just showing my turn it on again and it'll probably mess it up and it'll be too weak to run it for Sunday night to catch the mechanic in the morning. I don't have money for a tow truck and the mechanic.
Feb 8, 2020 at 1:57 PM
ROBERTA3
  • 9 POSTS
Thanks for all of your help.
Feb 8, 2020 at 1:59 PM
  • 110,241 POSTS
I understand. If I can do something to help, let me know. Also, since you are having it checked, if you have the chance, could you let me know what is found?
Feb 8, 2020 at 2:15 PM
ROBERTA3
  • 9 POSTS
I have a question I never had really made it to the mechanic because of when I got down here I parked it up and then you know almost all of a sudden a lot of bills to start powering up. so I still haven't made it down there, but I have a quick question. I have put a brand new battery in the truck and I turned everything off in the truck and I parked it next morning when I turn the truck on the battery battery was completely drain. I don't know if a cat could have cut one of the wires under the truck I don't know. but I know that nothing on it was on in the in the truck and the battery is completely drained. what can be the problem?
Feb 29, 2020 at 9:26 PM
ROBERTA3
  • 9 POSTS
I put a brand new battery inside of the vehicle nothing was on the inside of the truck when I turn the truck back on the battery was drained. nothing was on no light, headlights and nothing was on. I don't know if a cat could have cut one of the wires, but the battery is draining I don't know. what is might be the problem?
Feb 29, 2020 at 9:28 PM
  • 110,241 POSTS
Do you mean you installed a good battery and then got in the vehicle and it was dead?
Mar 1, 2020 at 10:18 AM
