The transmission fluid dip stick location
230,000 MILES • 3.0L • V6 • 4WD • MANUAL
JOSH ZOMANT
I don't see it anywhere.
Jul 21, 2020 at 7:43 PM
Good morning,
I attached a picture for you to view of the location.
It is right by the cover for the valve body on the side of the transmission.
Jul 21, 2020 at 8:51 PM
JOSH ZOMANT
Not auto, standard.
Jul 21, 2020 at 8:54 PM
Sorry, senior moment.
I attached a picture of the drain plug and the fill plug as well for you.
Change oil
1. Remove the filler plug.
2. Remove the drain plug and drain the oil.
3. Tighten the drain plug to the specified torque.
Tightening torque: 32 ± 2 N.m (24 ± 1 ft-lb)
4. Fill with Hypoid gear oil SAE 75W-90 or 75W-85W conforming to API classification GL-4 until the level comes to the lower portion of filler plug hole.
Quantity:
[2.4L Engine> 2.2 cu.dm (2.3 quarts)
[3.0L Engine> 2.8 cu.dm (3.0 quarts)
5. Tighten the filler plug to the specified torque.
Jul 21, 2020 at 9:13 PM
JOSH ZOMANT
Okay, so look my car starts but refuses to go into gear out of neutral. I Googled it and said it could be my neutral safety switch and to bypass it I just unhook it. but I do not know if it worked, but could it possibly been the problem cause?
Jul 24, 2020 at 4:09 AM
  • 55,562 POSTS
This is a different issue. Please post your new question here, you must be logged in.
Cheers, Ken
Jul 24, 2020 at 4:10 AM
