Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
CL
Exhaust
The exhaust is white and blue
2013 ACURA CL
328,080 MILES • 2.8L • V6 • TURBO • 2WD • AUTOMATIC
CAFEFADE
MEMBER
1 POST
The tail gas is white and blue. The engine oil is consumed quickly.
Apr 24, 2022 at 4:57 PM
Experienced Mechanic
There are a number of things that will cause these issues, but the most likely cause is a failing engine based on this info.
Here are a couple guides that will help with this:
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
What I would suggest is we start with checking the compression of the engine and find out if we have a ring issue and possible head gasket issue.
Please run through this and let me know what questions you have.
Apr 25, 2022 at 5:01 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
