Safety ignition switch replacement
17,500 MILES
DSWOREGON
How do I replace the safety ignition switch?
Jun 26, 2020 at 10:14 PM
Good morning,
Do you mean the neutral safety switch?
What is the exact issue toy have at the moment.
Park/Neutral Position (PNP) Switch Replacement
Removal Procedure
Caution: Refer to Battery Disconnect Caution in Service Precautions.
1. Disconnect the negative battery cable.
2. Remove the shift linkage.
3. Disconnect the electrical connector.
4. Remove the park/neutral position switch mounting bolts.
5. Remove the park/neutral position switch assembly.
Installation Procedure (Old Switch)
Using old Switch
1. Place the shift shaft in N (Neutral).
2. Align the flats of the shift shaft with the switch.
Jun 26, 2020 at 10:33 PM
