the running lights come on when i turn the key on & the vehicle keeps running when i keep the lights bvuit turn the key off
1990 GMC SUBURBAN
184,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
KJAMMON
The running lights(tail lights, sidelights & front marker lights) come on when turn the ignition key on & the
vehicle also keeps running when the headlights are on after I turn the ignition off.
Sep 19, 2015 at 6:21 AM
MIKE H R
  • 3,094 POSTS
check the wires under the dash to see if any are worn or crossed. The only other thing I would check would be the ignition switch itself not making the proper connection or bad.
Sep 21, 2015 at 4:01 PM
