Rear end pops when you turn
LEEHAMM3657
  • 1984 FORD MUSTANG
  • 0.5L
  • V8
  • MANUAL
  • 67,825 MILES
It just started you can feel it in the car.
Friday, February 2nd, 2018 AT 4:03 AM
CJ MEDEVAC
  • 11,005 POSTS
Does it have a posi-traction rear end? This happens when the sider gears or locked up.
The Medic
Friday, February 2nd, 2018 AT 5:43 PM
LEEHAMM3657
Yes and something popped loud and the drive shaft moves but do not move.
Friday, February 2nd, 2018 AT 6:03 PM
CJ MEDEVAC
  • 11,005 POSTS
You are saying that when you let the clutch out, the driveshaft rotates, the vehicle does not move.
I have to ask this one! Were you dogging it out when it happened?
The Medic
Friday, February 2nd, 2018 AT 6:29 PM
LEEHAMM3657
No, I did have to give it a little because car was coming. I was in town and my car is loud.
Friday, February 2nd, 2018 AT 9:12 PM
CJ MEDEVAC
  • 11,005 POSTS
In the beginning, I was going to suggest that maybe your differential was "popping" because that maybe your posi-traction differential lacked hypoid fluid (needed changing + hypoid additive) or needed to be driven in tight figure "8"s to lubricate the clutch discs within the differential.
After your second response, I am now leaning towards something broken within the differential (not good) or maybe you broke an axle (a little bit better!).
The Medic
Friday, February 2nd, 2018 AT 11:01 PM
