Air pump runs but the rear end does not level out
165,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
GEOMITCH1
So I replaced the pump, relay and airbags. Still the same thing pump runs but no lift. What makes matters worse I took the old pump apart it looks good, runs and piston and seals appear almost new.
May 10, 2019 at 8:18 AM
Good evening,
Do you any air leaks on the line to the rear bags from the pump? I would be sure air is being delivered to the rear bags first.
Make sure the height sensor in the back is connected as well.
May 10, 2019 at 8:51 AM
GEOMITCH1
I didn't hear any air leaks and no bubbles when I sprayed soapy water on the air connections on the pump/air dryer.
May 10, 2019 at 11:20 AM
Did you follow the lines all the way to the rear airbags?
May 11, 2019 at 6:50 AM
