The rear end dropped can only go about a foot in reverse
114,000 MILES • 2WD • AUTOMATIC
VLD7377
I was reversing and I hear a weird noise and then I could only reverse a foot before the car jolted to a stop. I got out to see and the whole rear end has dropped really low. I need to know what it is that could have happened.
Mar 31, 2021 at 9:52 PM
Good morning,
Are you sure the hand brake or emergency brake is not applied? It sounds like it is not released.
https://www.2carpros.com/articles/parking-brake-shoe-replacement
I attached pictures and procedures below for the parking brake system.
Mar 31, 2021 at 10:11 PM
VLD7377
The emergency brake doesn’t work in my car currently so I don’t believe that would be it. The brake on the passenger side rear was grinding really bad it was most likely metal on metal and made an awful noise constantly then it did what I described in the first question now the rear end of the car looks like it dropped way down.
Apr 1, 2021 at 1:51 AM
Okay, then most likely the rear shoes being metal on metal are causing the issue. You will need to replace the shoes and drums.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
I attached the procedure both in a guide and pictures below for you for the replacement.
Apr 1, 2021 at 2:20 AM
VLD7377
That would cause the whole rear end to drop and the car only being able to reverse a foot before jolting to a stop?
Apr 1, 2021 at 4:35 AM
Yes, it loads up the rear suspension and the rear will drop.
Apr 1, 2021 at 4:41 AM
  • 55,658 POSTS
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Apr 1, 2021 at 10:10 AM
