I recently noticed one of the front calipers getting stuck, so I replaced the cylinders and hose. During the hose replacement, I left it draining brake fluid until the master cylinder reservoir was empty. I put the new hose, the caliper in position, and filled the master cylinder with fresh brake fluid. I was trying to bleed the system with my friend, but we noticed that the cylinders never came out, the pedal feels "good". We started the car and the pedal went to the ground, we tried to bleed it out again with no luck. Now, I don't have brakes in the car, so I can't use them. :(
Do I need to bleed the master cylinder and maybe the ABS too? Please advise me !!
May 26, 2021 at 12:35 PM
