The passenger side headlight and brake light not working but signal lights and park lights are working fine
155,467 MILES • 1.5L • V8 • 4WD • AUTOMATIC
JENNIFER HOLBROOK
The headlights were just replaced with hallengions lamps now the headlight and brake light on passenger side not working but signal lights work and park lights work. interior lights work also.
Jul 13, 2021 at 12:51 PM
COLBY_STEPHENSON2000
  • 32 POSTS
Hello this is Colby,
I have seen this kind of thing before, the first thing i would do is remove the new right front bulb that was replaced and then see if the tail light starts working. If it does start working then it is a bad bulb or it was installed wrong.
Here are a couple guides that will help with this in case you need them.
https://www.2carpros.com/articles/how-to-replace-a-headlight-bulb
https://www.2carpros.com/articles/brake-lights-not-working
Let me know what you find. Thanks
Jul 14, 2021 at 1:18 AM
