The heater blower fan quite working completely
112,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
KEVINMULVIHILL
The heater blower fan does not work at all, just stopped working. I have checked the fuses for the blower under the dash board as well in the engine compartment. We had a prior problem with the fan blower about a year of two ago, it would only blow at certain speed the dealer fixed it at that time.
Jan 10, 2015 at 1:44 AM
HMAC300
  • 48,601 POSTS
check the blower relay which is under the hood then have it scaned because it may bethe speed controller or check brown wire going to it to see I it is getting power in. it's in center of hvac unit.
Jan 10, 2015 at 1:55 AM
