1997 Ford Explorer Front Blower motor will not work
1997 FORD EXPLORER
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENNETHT
Hi, Have a EB edition,with auto climate control. Front motor will not work. Fuse good. I have about 7V going to motor depending on fan switch setting. I have no neg signal going to motor. Any ideas of where to check?
Feb 7, 2010 at 4:21 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
Have you tried running a seperate ground to the motor? Have you tried running power directly to the motor to see if it will run?
Feb 11, 2010 at 2:18 PM
KENNETHT
Hello, yes motor does run with jumper wires. Does the motor pick up the neg through the resistor pack?
Feb 11, 2010 at 8:22 PM
