The fuse for EMISD 2 blows constantly and stops cooler fans and A/C
124,000 MILES • 3.7L • V6 • FWD • AUTOMATIC
JHIDALGO1961
On this 2007 Suzuki XL-7 the 15 amp fuse for the EMISD 2 (#20 on the fuse box diagram) blows constantly.
Every time the car runs with A/C for 10 - 15 minutes it happens again. The A/C stops working, the cooler fans don't work as well.
What should I do besides change the fuse?
Mar 4, 2014 at 3:24 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
somethings drawing too much amperage. the fans are usually the culprits. but check the fan relay and the plug it goes into for overheating first. you can smell burnt electrical, so when you unplug things smell them for a pungent burning smell. you can also CAREFULLY grab the fan power wires to feel for excess heat while the fans do run, that usually indicative of a fan that's wearing out
Mar 8, 2014 at 12:03 AM
